Yep, I'm using a fuse block but I'm just wondering if I still need to ground the battery to the frame seeing how my ground wiring is coming to a common point connected to the ground side of the battery.Miriam C. wrote:Mine go through a fuse and back to negative. Makes a loop!
A fuse block makes it easier.
No, grounding to the frame will not be necessary if you've already got completed circuits.Gage wrote:Yep, I'm using a fuse block but I'm just wondering if I still need to ground the battery to the frame seeing how my ground wiring is coming to a common point connected to the ground side of the battery.Miriam C. wrote:Mine go through a fuse and back to negative. Makes a loop!
bdosborn wrote:Gage,
You don't need to ground the frame to provide an electrical path if you have ground wires to all your devices. But you should still ground your frame. The idea is to create a return path from the frame to the battery so that the fuse blows if a hot wire ever rubs through and contacts the frame. That way you don't have an electrified frame waiting for someone to ground it. Now granted, its not much of a hazard at 12V but frame grounding is still good practice. And it can't be good for the negative ground tow vehicle to see 12V through the hitch. Commercially built trailers have the frame grounded as it's a code requirement.
flip18436572 wrote:I am new to the site, but what is the bad thing about grounding the frame also. I would automatically do that out of habit from building cars from the ground up???
Well, beings how I'm not building a car which you ground everything electrical to either the frame or body because there would be to many wires running to the battery and would look like crap and I also have no plans on running a hot wire between the car battery and the teardrop battery, I think I won't worry about running a ground wire to the frame. And I only have a couple of 'hot' wires and they are contained within a wooden box (big wooden box). So I have no worry about a wire accidently touching the frame and charging it up. Boy would the Raccoons get a shocking surprise with that.flip18436572 wrote:I am new to the site, but what is the bad thing about grounding the frame also. I would automatically do that out of habit from building cars from the ground up???
