Leigh wrote:Thanks for the info Bob & DH, had to cut grass yesterday before the rain hits and didnt get a chance to work on the tearddrop. I will be on it this afternoon and will let you guys know what I find. Loads of knowledge here, thanks again for sharing.
Leigh
Leigh wrote:Sorry Bob , I have made no progress. This week has been a little hectic. I do intend to try and solve my grounding problem this week. I am ready to drag it somewhere for a night or two. I did have someone tell me that because i painted my brackets that could also be a problem. ?? Anyway , maybe i will have chance to check some things tonight.
wannabefree
PostPosted: Thu Apr 29, 2010 10:32 pm Post subject: Reply with quote
What they said. Run a dedicated ground wire to each fixture. The HF lights ground through the frame. Every bolt together connection on that frame is a potential failure point. Even lights that work now will, sooner or later, quit working as the frame oxidizes.
The HF lights have a metal tab that sits under one of the mounting holes. This is the ground. Take a wire and crimp on a ring terminal. Pull out the mounting screw, slip the ring terminal under the metal tab and run the screw through the works. then run the other end of that wire up to your 4-flat connector. Splice it into the white wire and your light should work. Might as well do all the lights now. It's easier to do at home than on the side of the road somewhere Smile
_________________
-- Antoine de Saint-Exupery
