WFCO converter
Anything electric, AC or DC
Postby jimqpublic » Mon Nov 01, 2010 10:13 pm
George,
Sorry, you're talking about the Neutral (white) side of AC being bonded to the frame along with the AC ground?
Jim
2002 Chalet Arrowhead but always wanted a Teardrop
2 kids and a Dear Wife
http://community.webshots.com/user/jimqpublic
jimqpublic
Postby GeoDrop » Tue Nov 02, 2010 7:38 am
If you are talking about the WFCO, run a ground wire from the grounding block to the frame. This is actually depicted in the wiring diagram.
jimqpublic wrote:George,
Matthew (& Sandi)
The GeoDrop
GeoDrop
WARNING!
Postby GeoDrop » Tue Nov 02, 2010 7:43 am
For anyone using the WFCO converters.... pay attention to the wires exiting the box. On my unit (8725), a couple wires were badly pinched by the clamp they use to hold them in place. Over time, vibration would have likely caused a short.
Matthew (& Sandi)
The GeoDrop
GeoDrop
Postby cracker39 » Sun Nov 07, 2010 1:56 pm
Sonetpro's diagram helped me understand the confusing instructions that came with my WFCO converter. With that diagram, I got it all figured out and working (in 2006).
My new trailer may not have a converter. I may just install a marine type onboard computerized charger that is powered on and working anytime I have shore power connected to my separate AC circuits. It's simpler to install and does practically the same job. I'll install my breakers in a breaker box in my rear mounted shore cable box on the tongue. The battery, fuse block and charger will be in the other storage box on the tongue, so no breakers or fuses will actually be inside the cabin.
Dale
cracker39
Images: 233
Postby cracker39 » Wed Dec 15, 2010 1:10 pm
George Taylor wrote:This info is for everyone. I am an electrician and there is a section in the NEC (National Electric Code) that deals with campers. All metal frames need to be connected (bonded)to the negative side of your electric service.
The WFCO converter has a ground block that is grounded to the chassis. With only a 12VDC system, I would not use a frame ground.
Dale
cracker39
Images: 233
Postby George Taylor » Wed Dec 15, 2010 5:38 pm
Ok but where are you getting power for the converter to make the 12v?
George Taylor
Postby cracker39 » Wed Dec 15, 2010 7:40 pm
George Taylor wrote:Ok but where are you getting power for the converter to make the 12v?
Just look at the diagram above in Sonetpro's post. I think it's pretty clear.
Dale
cracker39
Images: 233
Postby GeoDrop » Thu Dec 16, 2010 11:17 am
http://tnttt.com/viewto ... highlight=
Matthew (& Sandi)
The GeoDrop
GeoDrop
Return to Electrical Secrets
