12v Power Supply on the Cheap!
Anything electric, AC or DC
Postby 07rascal » Fri Nov 05, 2010 6:05 pm
I wanted to be able to run our 12V lights and Fantastic Fan even when plugged into shore power without having to plug in our battery jumper pack (That is what we use for 12v power, instead of an on-board battery). So I came up with this solution. 12V 3amp power supply from Amazon, $16.99. Installed as shown and plugs into our 110v power strip. I put a female cig plug on the 12V output and we simply plug our male cig plug (that normally plugs into our power pack) into the female of the power supply. This line has a fuse in it already. This way we can leave the jump starter in the car and still get our 12V. A poor mans "converter" without the battery charging feature!!
We dry camp 90% of the time, but this will give us this option when on shore power the other 10%.
Link to the power supply (I see the price has changed just in a week since buying it): http://www.amazon.com/gp/product/B0002J ... ss_product
Here is a pic of the final install.
This is a pic of our Fantastic Fan that we installed about 2 weeks ago. The toggle switch next to the light is the reversing switch to change directions of the fan from exhaust to blowing in.
Terry & Lisa
From our LG Rascal to the Cabin-A.....The LG found a good home!
"When employed, live like your unemployed....so that when your unemployed you can live like your employed!!"
07rascal
Power To The People
Postby Engineer Guy » Sat Nov 06, 2010 8:31 am
Great idea on the lil Power Supply. Keeps it simple and versatile.
For my last expedition, I updated a few things on the cheap; cheap being a goal of the trip. For 12 VDC Cig Lighter Plugs, I went to the local version of Habitat For Humanity, and Salvation Army. They have a bucket full of cords and plugs. I got some fused 12 VDC Plugs w/cords for a $1- each. Then, I can solder on the other end whatever I need.
Various lil Adapters/Power Supplies that supply up to ~1 Amp are also handy and cheap. Yeah, they take up some room on the Power Strip and they represent 'phantom loads' of current draw, but sometimes a lil low voltage is all that's needed. Switch off the Power Strip as req'd. 'Switching'-type Adapters, as sometimes used for Cellphones, are nice and compact. However, they output current only when a certain size of load is put on them. This tradeoff is how Designers get the Adapter size down. So, some of these Cig Lighter Adapters from old Cellphones can be re-plugged to run other gizmos; sometimes not.
A handy lil item I've had for years is this multi-voltage Adapter:
http://www.radioshack.com/product/index.jsp?productId=3875413
Pals from Scotland left us a lil Battery Charger they bought here. ~Half the size of a Pop Can, it plugs into 115 VAC and charges 4 x AA and 4 x AAA Batteries. I went to rechargeables on all my toys, including 2/$5-, very kewl lil LED Flashlights the size of a Pill Bottle that use 3 x AAAs, bought at discounter 'Big Lots'. These flashlights were easy to hold by mouth when both hands were busy, and got a real workout in dark skies around Camp. Using some Cig Lighter plugs/cords can cut down on the number of Lantern and other batteries while utilizing the high capacity Trailer battery. In my case, I took a spare Deep Cycle and recharged it while charging other batteries simultaneous with running this Laptop. The 'right'-sized Solar Panel from HF or elsewhere is another charging option that doesn't burn dead Dinosaurs.
This ~$ 26- Inverter got rave reviews from RVers for durability and a quiet fan, and outputs 'enough' 115 VAC to power most anything [like a 115 VAC Soldering Iron]. You can also charge/run 115 VAC items while driving while having modest backup for Home power loss 'events'.
http://www.amazon.com/Cobra-400-Watt-12-Volt-120-Volt-Inverter/dp/B001RNOHBC/ref=sr_1_1?ie=UTF8&qid=1289048810&sr=8-1
A cheap, end-of-Season Tiki Torch from HD burning Citronella Oil was perfect for Camp light when the ole Coleman was overkill in dark skies.
~Reality proceeds with or without your consensus~
Engineer Guy
Images: 118
Postby 07rascal » Sat Nov 06, 2010 5:46 pm
We have a Habitat For Humanity store in our town, and I never thought about that for a source of "out of the box" ideas.....until now! Great idea, will have to pay them a visit next time I am by there.
Terry & Lisa
07rascal
Postby Jst83 » Thu Dec 16, 2010 7:27 am
That may be just the thing I'm looking for, I run 110v about 100% of the the time but want to put a vent fan and in my new little camper and most seem to be 12v. this might just be the thing i need to run the fan off of shore power while keeping everything else 110v if I'm folloing it correctly. :thumbsup:
Jst83
Images: 215
Postby H-Balm » Sun Jan 09, 2011 7:56 am
On a side note...
Is that an orange leaf blower in your Teardrop?!!?!
:shock:
H-Balm
Postby 07rascal » Wed Mar 02, 2011 9:20 am
Ha! Yep and a B&D 18v Weedwacker......never call us "unprepared"! :D
Terry & Lisa
07rascal
Return to Electrical Secrets
