B@tt wrote:Found a pretty good deal on a WFCO 8935 while actually looking for an 8725. I have not seen anyone here use the 8900 series, are there draw backs to it vs. 8700 series? (other than size)
I will be instalingl this in my 6x14 Cargo Conversion and can accomidate either in the space. Is the 8700 series easier to wire? does the 8900 series require anything extra?
-B@tt
The 8735 & 8745 have AC & DC distribution (which is desirable).
The 8935 & more power versions have AC & DC distribution also.
Both have 3 stage charging.
I have installed two 8900 series WFCO converters (8945 & 8955) in van conversions. I , also, had one that came with a trailer. They worked very well. I liked the integrated AC & DC distribution. I used the 8900 series for charging D4 size batteries (200 amp/hr). Wiring is very easy. It should be the same for 8735, 8745, & 8900 series converters.
The size battery that you use should determine the converter size that you install. If you will install a big battery, get a powerful converter.
If you get a large (output amps) converter it will charge the battery faster.
