Not a troll question. Yes, I'm looking for the CEE 7/4 or 7/7 hybrid "Shuko" style inlet. Were building a new test shed at work. I can find the US types all day long, but my Google-Fu has run out trying to find the European one.
Your links look like they will work. I'll check Mouser and Allied.
Here's the plug and socket pictures from "wikipedia". Our typical European products are built with the 2 pin "europlug" but I need to be able to use the 7/4 or 7/7 Hybrid with earth connection as well for the test shed, since occasionally we use that style plug also.
I guess my question now is which one of these two below do I need? I plan on using an off-the-shelf "extension cord" to make the connections. Or will either one work?
http://www.internationalconfig.com/icc6.asp?item=70195http://www.internationalconfig.com/icc6.asp?item=70198I will probably make my own "extension cord" since I will want a custom length using these:
http://www.internationalconfig.com/icc6.asp?item=70141http://www.internationalconfig.com/icc6 ... em=70161-ALooks like I want to use the first one? (70195?)
