Gerald_G wrote:Thanks Podunkfla.
I should have thought of that, but it does still have one issue. Each fixture has a switch, so unless I bypass the switche on one and wire in the switch on the second, it could be a problem.
I'd have to turn them both on at a time, not one at a time that way.
Gerald_G wrote:I considered the dual 6V idea. Apperently the big trailer guys do this for more battery life. Not sure I want to add two batteries though. (not just for LED lights.)
bdosborn wrote:Why not build a cheap voltage converter? This one is good for around an amp at any voltage you want.
http://www.uoguelph.ca/~antoon/circ/ps-lm317.html
SSchumacherCO wrote:Or you could buy a cheap voltage converter. One that plugs into the lighter used for cell phones and the like. Just find one that puts out 6 volts and at least the current you need. RadioShack sells generic ones fairly cheap. Rip out the guts or use as is with an inline socket.
Podunkfla wrote:Hmmm... Sometimes the best answer is just so obvious we overlook it?
