tonyj wrote:I have been trying to decide if I should just replace the battery with an non-venting battery (Optima) since the charge on this battery is creating vast amount of fumes. My other option is to replace the tender with the 1.25 amp model.
Any thoughts?
halfdome, Danny wrote:I just had a long talk with one of the tech guys at Battery Mart about my Battery Tender. I've been noticing my voltmeter reads a little higher every day and it got up to 17.10 volts. He said what I'm seeing is the current of the Battery Tender in the float mode and the charge on the batteries and it's okay. He had me unplug the Battery Tender and said it should settle down into the 14 volt range. In a couple minutes I ended up with 14.03 volts for both batteries, which is just fine....
brian_bp wrote:This makes no sense to me. If it is really in float mode, the voltage would be at the float level, much less than 17 volts. If the voltage is climbing, the charger is putting out too much voltage.
It sounds like the charger was in charge (not float) mode, and when unplugged and reconnected it saw a high enough battery voltage that it actually went into float mode.
The point of a "battery tender" is that you don't have to tend to it yourself, by resetting it twice a month. If you're going to do that, you might as well use any "smart" charger to do one charge cycle each semi-monthly cycle, and leave it on a plain float supply the rest of the time... or just leave it disconnected between charges, because batteries can go two weeks without a tender.
madjack wrote:I plan on using the 5a model as a "convertor" hooked up over the battery to provide all needed 12v power.................
