by 01Sport » Tue Jun 09, 2009 1:05 pm
OK, so if I only have 2 speakers, I will use the 2 speaker wires, I believe gray/black and white/black (I don't have it in front of me so I don't know that for sure), then the black, do I ground this directly to the frame or can it go to the ground on the fuse block?, and then the power. The power is where I may be lost a little. I use the red and yellow? Do they both get wired together to the positive wire that runs to the fuse block? Do I need to wire this directly to the battery or is running it to the block ok? The wire harness has an inline 5 amp fuse, do I need another 5 amp fuse at the block? This part is always foreign to me, thanks for your help.
K.C.
Teardrop Name: Golden State Teardrop
