Flat Screen TV
Flat Screen TV
Postby DTCOOPER » Thu Feb 21, 2013 9:29 am
Okay guys, in my quest to finish my CT conversion; I have come upon a 17" Samsung flat screen TV. It's a 120 volt unit, that uses a power supply, much like a laptop power supply.
The output of that PS is 14v DC @ 3 amps.
I am wondering if I can just hook the TV directly to my CT 12v system?
I mean on shore power, my converter panel is putting out 13.6 volts. And when off of shore power, my batteries are 12.6-12.8 ?
Shouldn't this work, or is my thinking flawed ?? :thinking:
Because I have a constitutional right to, that's why!!
2007 Tundra Tow Vehicle
2004 Road King for riding
Kawasaki mule, 4 wheelers, and other toys for playing!!!
DTCOOPER
Re: Flat Screen TV
Postby Greg M » Thu Feb 21, 2013 11:25 am
It should work fine on shore power, and I'd guess about an 80% chance of working on just the batteries. Low voltage won't hurt it, it simply won't turn on. I say give it a try.
Greg M
*Geek Extraordinaire
Images: 85
Re: Flat Screen TV
Postby Dean in Ct. » Thu Feb 21, 2013 4:32 pm
And please let us all know the results! I've been thinking along those lines myself, but with a smaller screen if possible.
Dean in Ct.
Images: 32
Re: Flat Screen TV
Postby DTCOOPER » Thu Feb 21, 2013 4:48 pm
With this newly found gusto, I will be trying it this evening. :twisted:
I'll let you all know how it goes, when I get out the tablet to surf and post some pics :pictures: at bedtime ! :beer:
DTCOOPER
Re: Flat Screen TV
Postby RandyG » Thu Feb 21, 2013 5:55 pm
Be sure to get the + and - correct :thumbsup:
Randy
RandyG
Images: 115
Re: Flat Screen TV
Postby DTCOOPER » Thu Feb 21, 2013 10:09 pm
Good news: it works. :D loaded up 12v system. Drew it down to 11.9v and still worked. With converter plugged in, I had 13.8 and it worked fine.
Now the "other news":
I have a winegard RV amplified antenna. To get benefit from it, I'd need a digital tuner TV or a converter box. The Samsung TV I have is analog. To use TV without antenna, I'll be relegated to DVDs. That'll require 120v anyway. I had installed a 120 receptacle there on the cabinet where I'm mounting the TV anyway. So for the time being I'll just use it as 120v w/ the DVD player.
But if I can find an inexpensive digital flat screen that uses a low voltage power supply; I'll be all set. :lol:
DTCOOPER
Re: Flat Screen TV
Postby Greg M » Fri Feb 22, 2013 12:14 am
Yay!
How old is this TV? I don't think I've seen a flat screen without a built in digital tuner in about 5 years.
Greg M
Images: 85
Re: Flat Screen TV
Postby KevinC » Fri Feb 22, 2013 4:06 am
Greg M wrote:Yay!
That is the same thing I was thinking but maybe it's a "flat screen" and not a "flat panel" tv. ??? :thinking:
They came out with regular CRT (tube) TVs that had flat screens a while before everything went digital.
Subscribe FREE at:http://www.cooltears.com
KevinC
Re: Flat Screen TV
Postby DTCOOPER » Fri Feb 22, 2013 9:02 am
it's a Samsung LTM1755B.. Definitely a flat panel TV.. Just can't seem to find anything that says it's got a ATSC tuner.. Only NTSC.
I'd love to find that I'm incorrect.. But from what I read, anything that has a digital tuner will be ATSC. This TV was produced in 2007 I believe.. A couple of years before the required digital conversion.
DTCOOPER
Re: Flat Screen TV
Postby pchast » Fri Feb 22, 2013 11:04 am
USB powered displays (5v) are now available up to 22" diagonal at http://www.tigerdirect.com/applications ... ed+display. :D
I haven't tried one yet. Its on my list.
Pete
pchast
Images: 97
Re: Flat Screen TV
Postby Greg M » Fri Feb 22, 2013 12:04 pm
Hook it up and do a channel scan. I just got given an old series 3 Samsung that has no mention of a digital tuner in the manual, but it does have it inside. You might get lucky.
Greg M
Images: 85
Re: Flat Screen TV
Postby droid_ca » Fri Feb 22, 2013 3:27 pm
I'm using a Jensen 12 volt 32 inch the picture quality is excelent
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Re: Flat Screen TV
Postby RandyG » Fri Feb 22, 2013 4:07 pm
Jensen makes a 12v dvd player that you can use so you don't need the 120. I've seen them in newer rv's.
How long will one battery run a 20-22" flat screen?
Randy
RandyG
Images: 115
Re: Flat Screen TV
Postby bdosborn » Sat Feb 23, 2013 2:08 pm
I'd do some checking on the Jensen power draw before you buy one (they're also pretty spendy). I think you'll find you can get an LED flat screen that uses half the power. Just use a small inverter for power. Vizio from Wal Mart seemed to give the most bang for the buck when I was looking at them. For comparison, here's a Vizio 19" versus a Jensen 19".
Vizio LED $128
Power Consumption: 25W
Jensen $399
Power Consumption: 50W
The LED TVs have the lowest current draw (the Jensen isn't an LED). TVs are changing so fast its hard to keep up with what the latest, bestest stuff is.
Images: 806
Re: Flat Screen TV
Postby bdosborn » Sat Feb 23, 2013 10:44 pm
slowcowboy wrote:is a tv really constute camping gear???????????????????????
That took way longer than usual slow, you're really slacking off. :lol:
Images: 806
