GuitarPhotog wrote:You need to put 120 VAC breakers in the PD for the Master power and for the Converter itself, plus one for each 120 VAC circuit you want to protect. My PD4045 has two double breakers, one 20+20 for the master and converter and one 15+15 for the branch circuits.
You will need to buy and install automotive-type fuses for each DC circuit.
You need a fuse near/at the battery. I use an on-line fuse holder for this so I can mount it right at the battery terminal.
I wired a Main Battery disconnect switch to the terminals in the PD. It however does not disconnect the parasitic load of the converter electronics, so there's always a small power draw.
<Chas>
Gunguy05 wrote:GuitarPhotog wrote:You need to put 120 VAC breakers in the PD for the Master power and for the Converter itself, plus one for each 120 VAC circuit you want to protect. My PD4045 has two double breakers, one 20+20 for the master and converter and one 15+15 for the branch circuits.
<Chas>
So my shore power runs directly into the PD?
les45 wrote:The master breaker does not cut the battery power. It only cuts the DC that is made by the converter. In fact the battery is meant to run when shore power is not available unless you do install a master cutoff switch. I installed my master battery cutoff switch in the positive battery lead before it entered the PD using a standard AC house switch. The switch is mounted above the PD and facing the galley for easy access. BTW - on your list of things, I would highly recommend using GFCI outlets in your AC system, especially for your "outdoor" outlets in the galley.
Shadow Catcher wrote:The one thing I will add is have more outlets than you think you will want . Both 120AC and 12V.
les45 wrote:Shadow Catcher wrote:The one thing I will add is have more outlets than you think you will want . Both 120AC and 12V.
+1 on that; I originally installed one AC outlet in the cabin and two GFCI outlets in the galley. I ended up adding an AC outlet, two DC outlets, and a USB port inside the cabin. One AC outlet wasn't enough for heater, laptop, speaker amplifier, and iPad/iPhone chargers. Also added one DC outlet in the galley for miscellaneous gadget charging.
<Chas>
