110 Volt Breaker Box Help Please
Postby Sonetpro » Sun Dec 10, 2006 7:16 pm
bdosborn wrote:
steve wolverton wrote:
According to the stuff I'm reading, the ground isn't even really needed in the system, but is used to prevent "shock."
It's not used to conduct load current but to carry away accidental shorts. Sorry for using so many "no"s. After reading this again I came on a bit strong. People will be calling me George before long... :oops:
We will just call you Bruce T. :rofl:
Sonetpro
Images: 107
Postby bledsoe3 » Sun Dec 10, 2006 10:26 pm
Ouch!
bledsoe3
Images: 112
Postby Kevin A » Sun Dec 10, 2006 10:33 pm
OUCH is right,
I don't think Bruce has anything to worry about, there's only one George.
:lol: :lol: :lol:
Kevin A
The other guy
Images: 289
Postby sdtripper2 » Sun Dec 10, 2006 10:51 pm
Steve W wrote:I'm going to run down to Walmart to see if I can find a converter for
that funky 30 amp service plug to a conventional 15 amp house plug so I
can plug it in and see if it works.
Steve:
Here is one of many choices on the market for an adapter.
Here is one link to an adapter. http://tinyurl.com/h9ua9
Most of this basic adapter would cost less than 3 bucks.
Some with pigtails will cost more.
You could have a 30A adapter plug shown here from Camping world
RV supply or Walmart. If the power at the campground is ONLY 30 amp
service for some reason your 15 amp outlet at the site has bad magic
you can use this adapter to get power from another circuit at the panel.
You could have a circuit tester also to be sure you have the right polarity
at your park supplied AC outlet.
Carry an inexpensive tester that you can get at Home Depot or other electric shops.
I have used both of these tools and one time found a campground outlet
that had an incorrect ground.
sdtripper2
Search Garoux
Images: 168
Postby steve wolverton » Mon Dec 11, 2006 12:22 am
sdtripper2 - I used to have one of those adapters but can't find it now. I guess I sold it with my popup. :( I ran to Walmart tonight, but they didn't have one. I've finished my wiring job, and I have no idea if it works, but I don't anticipate any problems. I'm taking an extension cord and a power strip just in case though. ;)
As for the tester, I picked one of those up when I purchased my wiring. I plan to check the campsite plugs before hooking up.
Thanks for the info. :thumbsup:
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby steve wolverton » Mon Dec 11, 2006 8:11 pm
Success! I found an adapter (30 -> 20) at Lowes tonight. I plugged it in, flipped my breaker, flipped a switch and I have light! Both outlets installed also read "correct" according to my tester.
What a rewarding feeling for my first 110v job.
:dancing
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby Miriam C. » Mon Dec 11, 2006 9:49 pm
:applause: :thumbsup: ;) Congratulations Steve.
We'll just call you sparky now. :lol: Remember to post lots of pictures cause ya know they help.
Did you get that hair dryer up yet? ;)
Postby bdosborn » Mon Dec 11, 2006 10:27 pm
steve wolverton wrote:Success! I found an adapter (30 -> 20) at Lowes tonight. I plugged it in, flipped my breaker, flipped a switch and I have light! Both outlets installed also read "correct" according to my tester.
:dancing
Keep that tester handy. You'll probably want to rewire the house now.
"Needs more power... arr arr arr arr"
Images: 806
