WFCO conveter
Extra 30 Amp fuse
Postby dh » Fri Aug 21, 2009 9:02 pm
Should you put a 30A fuse close to the battery, to protect the wiring when running off the battery, and a second by the WFCO to protect the wiring while charging???
dh
Re: Extra 30 Amp fuse
Postby madjack » Fri Aug 21, 2009 9:14 pm
dh wrote:Should you put a 30A fuse close to the battery, to protect the wiring when running off the battery, and a second by the WFCO to protect the wiring while charging???
...yep on the battery side...I believe the charging circuit is already fused at the converter.............. 8)
