It gives the basic idea pretty well. Now if you know a better one that is just the basics please share.
BPFox wrote:Inverter vs Converter. Many times on this web site I have read about these devices as if they are separate systems. They are not. At the end of the day you will either have a Direct Current System or an Alternating Current System, or both. Inverters and Converters are just devices that are part of the above listed systems. They can be confusing since we are pretty much told to not combine our 12 volt dc and our 120 volt ac systems together and that's exactly what inverters and converters do. Keep in mind that these devices are just part of their respective systems. The "converter" is part of the Alternating Current system. It will keep your 12 volt battery from discharging and allow you to use your 12 volt dc system while connected to an outside 120 volt power source. The "inverter" on the other hand, is part of the Direct Current system...
Before we lead someone astray, while you have your system wired correctly (white to silver) (black to gold ) the white wire is neutral and the black is hot.pete.wilson wrote:Hey
I use a 2200 watt inverter for my AC needs and I use two series 31 trolling motor batteries that I bought at Cabelas(6awg wires from batts to inverter). Fully charged they will run my microwave oven, fan and a few other things for 2 days with no problem. A electric ceramic heater keeps thing warm but does draw some juice. My batteries are connected in parrallel, then there is a large fuse in-line on the red lead. Ground is ground, batteries to the inverter. My cord from the inverter outlet to the wall outlet boxes is from a 14 gauge 3 wire 100ft extension cord, I used it because its supple and for short runs works fine w/o heating issues. I used standard house blue electrical boxes. White wire is hot to the shiny nickel screw on the outlets, black is neutral and goes to the brass screw on the outlets and green is ground and goes to the outlet gnd. lug. Note: If using a ceramic heater or other appliance over 1500 watts, then I would go to a 12awg cord/wiring. My inverter has built in circuit breakers if needed. I fused the 12v red lead but you could use a circuit breaker also. Also useful is a battery isolator switch which allows you batt 1, batt 2 or none. I also have a 2amp trickle charge built in to charge things when the batteries are tucked away and easy access isn't needed. A small 12v digital voltmeter that plugs into a 12v oulet (walmart has then in automotive for about $15) is handy for keeping track of your batts. condition while your camping.
Keep in mind if your going to have four batteries; make sure your weight is distributed equally, ie. two batts left of center, 2 batts righ of center, same distance front to back in your setup.
Pete Wilson
