ground and fuse jumpers
Postby Larwyn » Sun Sep 07, 2008 7:52 am
rhltechie wrote:I think i have espn cause i knew you would say "it depends" :lol: I concur with your running it a bit bigger than you might need. i have started a spreadsheet of all the things i will be running...so i will see what comes of it. i have plenty of time to decide all of this as i havent even gotten started!
i REALLY appreciate all of your responses to my inquiring mind :)
Glad to help. :thumbsup:
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
Postby BPFox » Sun Sep 07, 2008 11:08 am
Larwyn's suggestions are spot on. Using a fuse panel that has a buss bar on one side is cleaner and has less connections to worry about than using jumpers. It is, however, more expensive. That said, your electrical systems are probably not a good place to cut corners. When considering your build, it might also be wise to leave some extra room for future consideration. So after you make your calculations on what size wire you need to bring from the battery, think about bringing it with one size larger. It's always better to have it and not need than to need it and not have it. Keep asking those questions, we are all here to help. Peace.
BPFox
