110 Question
Re: Easy 110 Set-up
Postby bobhenry » Fri Oct 16, 2009 8:10 am
SATEAR wrote:Well.....since you all think its that easy to set up a TD for 110. Does anyone have a plan or pics to put in plugs and lights for a TD using 110 only?
Much appreciated!
Here is the best source I have found http://www.diyadvice.com/diy/electrical/?ordersrc=yahoo1homeelectrical_cgy&cobrandId=ww5&s_kwcid=TC-16399-233085572022-S-46937429022
Remember black to gold white to silver
Postby starleen2 » Fri Oct 16, 2009 1:55 pm
Here’s my modified power panel and everything plugs into it from shore power. Those black boxes are 15 amp 4 receptacle extension cords that plug in to the power box
starleen2
5th Teardrop Club
Postby bobhenry » Sat Oct 17, 2009 1:55 am
Postby Uncle Chan » Sat Oct 17, 2009 9:49 pm
It can be just this easy:
Cut a hole in the TD and install this:
Here it is, installed:
This is the pigtail inside the TD (Then I plugged a powerstrip with a breaker in it.):
This is the power cord from the 110 source to the TD:
Uncle Chan
Uncle Chan
Thanks for the Input!
Postby SATEAR » Thu Oct 22, 2009 9:23 pm
After a Boy Scout campout with my 11year old this weekend, it's back to work on the TD. I found a marine supply store to pick up one of the plugs and will install this next weekend hopefully. Thanks, Gabe
SATEAR
Images: 75
