yep, that is how it is done on my boat trailer and so far, 13yrs and no light problems.............
Dale M. wrote:Contrary to all know mechanical connection knowledge in universe, a star (tooth type) lock washer between ground connector and frame is best possible way to insure a good mechanical connection.... Forget chemical rust stripper and use rotary wheel (grinding) on electric drill to find clean fresh metal.....
Dale
wlooper89 wrote:Dale M. wrote:Contrary to all know mechanical connection knowledge in universe, a star (tooth type) lock washer between ground connector and frame is best possible way to insure a good mechanical connection.... Forget chemical rust stripper and use rotary wheel (grinding) on electric drill to find clean fresh metal.....
Dale
Thank you for your suggestions. The place I want to put the grounding post is painted and not rusted. The grinder should be good on that to clean down to metal or perhaps start with a chisel. Attach the post then use primer and paint.
There are some rust spots in other places where I may try the Naval Jelly and then prime and paint. Have never used Naval Jelly and am interested to see how that will work.
Bill
Miriam C. wrote:Be sure to sand after the Naval Jelly where you put your post. You get more than one grounding post because you might need one on each side and the front/back..........short runs tend to waste less wire and less chance of a break.
wlooper89 wrote:Miriam C. wrote:Be sure to sand after the Naval Jelly where you put your post. You get more than one grounding post because you might need one on each side and the front/back..........short runs tend to waste less wire and less chance of a break.
Thank you Miriam. Those are good ideas. I have just two wires to attach, both #10, one AC and one DC. But having each on a separate post may ensure better connections. And mounting them on opposite sides of the same attach point will save drilling a second hole.
Bill
Miriam C. wrote:You definitely want them on a separate ground. I am still not sure why some are grounding AC. Mine isn't and it works just fine.
BC Dave wrote:Bill good explanation! full marks on the why to ground AC.
I'm just in the process of installing AC; I ended up grounding the main inlet and the first GFC outlet that all others are connected to (so all outlets are GFC through the first, great suggestion from another TDer).
I used a medum-small bolt; toothed washer & bolt through a drillled hole in the frame; scraped to bare metal; tightened good & tight ...THEN ... used another 2 toothed washers to sandwich & squished the copper wire with a second nut; seemed to work quite well; oh and used liquid electrical tape to paint over.
My 2 cents on AC groundingCheers BC Dave
