JEEP - Right Side Trailer turn/stop Lights not working
Postby Shadow Catcher » Tue Jan 05, 2010 6:38 am
There are heavy duty modules available that can be spliced in if the OEM part is not available when the time comes that you want to do some towing. Some are powered from the battery rather than the tail light wiring.
http://www.drawtite.com/modulite1.htm
Note this one is compatible with Jeep which has the warning for the Jeep Grand Cherokee
"Do not connect trailer lighting system directly to the lighting system of your vehicle. Failure to comply could damage the vehicle electrical system and/or result in person injury."
Postby Mark72 » Wed Jan 06, 2010 5:50 pm
Have you thought to test the trailer? Often a light with no ground will backfeed through both elements of the bulb to get a ground thus rendering the other circuit inoperable.
Mark
Mark72
Images: 127
Postby Frog » Fri Jan 15, 2010 1:58 am
bytehoven:
Sounds like you should have your own parking space a the dealer.
Frog
