![Cool 8)](./images/smilies/econ_kewl.gif)
asianflava wrote:I was thinking, like Kevin said, isolate the wiring from the frame. Then hook the positive and ground thru a DPDT switch. One side will be reversed from the other. Flip the switch one way it will have negative ground, flip it the other and it will be negative ground. You just have to make sure that you have it flipped the right way before connection the harness.
Brad Lustig wrote:I'd thought about using relays and will look into it when it comes time. It would definitely make a unique setup and probably fairly simple
