Hopkins 5 wire to 4 wire converter.
Re: Hopkins 5 wire to 4 wire converter.
Postby Dale M. » Thu Apr 18, 2013 10:02 am
Also consider not all converts are same... Maybe the converter you purchased is not correct choice for your application... I smoked several till I found that would work reasonable well on a Honda Passport I used to own.... I really do not like them As I found them to be somewhat unreliable....
IF you have little success with converter you have, you might consider one of these...
http://www.etrailer.com/t1-1989_Toyota_Pickup.htm
Dale
Dale M.
Images: 18
Postby Irving » Fri Apr 19, 2013 8:36 am
eamarquardt wrote:
Irving wrote:
eamarquardt wrote:Why not install lights and wiring on the trailer to match the tow vehicle. I'm sure you could make it so that you'd be able to use it with a regular 4 wire vehicle and a 5 wire vehicle with a little thought and perhaps an extra plug/socket.
Go with the flow.
Gus
I thought about that, but I'd like to be able to tow the trailer with more than one vehicle.
You easily could. Wire your truck and trailer with a 4 wire connector. Ground, tail lights, right and left brake light all wired separately. Add two more wires and dedicated turn signal lights to your trailer and a separate connector for the right and left turn signals on your truck. So, if you plug into your truck you connect the additional turn signals you've installed on your trailer. If you plug into a conventional vehicle your brake lights function as the turn signals and your extra turn lights are non functional. You could always add a switch on the trailer to connect your extra turn signals to the brake/turn signal wires so the extra lights would function 4 wire or 5(really 6) wire.
Where there is a will, there is a way. Doing it this way would eliminate the converter module. It sounds more complicated than it would actually be.
I think I'd do it w/o the converter and have, as you'd like to, the ability to tow it with any vehicle.
Hope this helps.
Gus
That's not a bad idea, and I might do it. I'm trying to see in my minds eye just where I'd put a switch to use the extra blinkers with a conventional vehicle in conjunction with the brake light blinkers and I'm drawing a blank..
Irving
Postby Irving » Fri Apr 19, 2013 5:43 pm
THE CONVERTER WAS BAD! Bought a new one and it works great.
Only thing I'm dissatisfied with is the intermittent slight dimming that the opposite light gets when a blinker is flashing. Normal I guess.
Irving
Postby eamarquardt » Fri Apr 19, 2013 7:39 pm
Irving wrote:
eamarquardt wrote:
Go with the flow.
Gus
Hope this helps.
Gus
Not that it matters now but the switch would be on the trailer. A double pole single or double throw. One way the switch would connect the dedicated turn signal lights to the brake/turn lights when thrown the other way the turn signal lights would be disconnected from the brake lights and be fed by the separate turn signal wires.
Gus
eamarquardt
Images: 150
Postby Dale M. » Fri Apr 19, 2013 9:31 pm
Irving wrote:THE CONVERTER WAS BAD! Bought a new one and it works great.
Crappy converter... Poor product....
Dale
Dale M.
Images: 18
