- I vote to have this sticky-ed; I know this is touched on in other electrical threads. but should be highlighted.
There's good knowledgeable comment here on why and why not and how to properly ground to a frame, tipping my hat to Bruce & Dale "et al". Generally, due to the rules, its not permitted to ground you 12V negative to frame in an RV, so there's no chance to a hot frame due to a 12 V positive touching a 12V ground to frame ... to be clear on the 120V side you need to have the green 120 ground bonded to the frame. Correct me if I'm wrong.
I learnt something here and I wished I ran separate black negatives back to the battery, but grounded to the frame like all automotive. That being so I haven't had any issues with the 12V negative being bonded the frame and it would also be connected via the hitch to a tow vehicle anyway.
So what issues might I have with plugging in to the tow vehicle with a frame 12V negative & a 120V grounded to the frame; charging while towing or can there be any issues with a 120V converter charger? (geez there is a lot to consider and worry about
I'm just about to add a 45amp converter charger and that's a fair amount of amperage potential to go through a frame -yikes!- or I just isolate that I guess but I can do that ...I have to run the negative to frame now as its set up ...
Cheers BC Dave
