No power to panel?
Re: No power to panel?
Postby zroadhouse » Thu Apr 09, 2015 4:04 pm
Dale, thank you for your helpful reply. I have a GFCI tester similar to what you show. Yesterday I also unhooked everything from the panel (including the power in!!) and still had no dice with the GFCI on the house. I strongly suspect that I either did something wrong when I rewired the inlet (likely) or that there is actually a short somewhere else (insulation rubbed through).
By re-wiring the inlet with fresh 10 gauge cable, I should be able to more easily test that the inlet is good. Then I can move on to systematically checking the panel wiring one circuit at a time as you described.
zroadhouse
Images: 103
Postby zroadhouse » Thu Apr 09, 2015 6:47 pm
Hot and ground (black and green) are connected somewhere.
zroadhouse
Images: 103
Postby zroadhouse » Thu Apr 09, 2015 9:58 pm
Looks like I caused the short when I put the inlet back together by clamping the hot wire against the ground wire. I carefully reassembled the inlet with new wire, plugged in, and seems good. Now to carefully rewire the panel. :)
zroadhouse
Images: 103
Postby zroadhouse » Thu Apr 09, 2015 10:27 pm
Success! My outlet on the trailer tests green!
zroadhouse
Images: 103
Postby MtnDon » Thu Apr 09, 2015 10:48 pm
:thumbsup: :applause:
MtnDon
Images: 24
Postby zroadhouse » Fri Apr 10, 2015 12:22 pm
No thread would be complete without pictures. So here are some I took while figuring stuff out. Thanks to everyone who helped!
130488
130489
130490
130491
zroadhouse
Images: 103
