24V Solar Panel, 12 V Battery
Re: 24V Solar Panel, 12 V Battery
Postby dales133 » Wed Sep 23, 2015 4:20 am
How many pannels can you get?
I'd pay postage and beer bribes for them
dales133
Postby bobhenry » Wed Sep 23, 2015 7:51 am
I am kinda dense but why could you not charge 4 6 volt batteries in series (24 volts) then center tap at each pair of batteries to draw of 12 volts only.
Am I way off base?
Postby jss06 » Wed Sep 23, 2015 9:12 am
It would be difficult to isolate the charging circuit from the load circuit to do that.
jss06
Palladium Donating Member
Postby MtnDon » Wed Sep 23, 2015 9:19 am
bobhenry wrote:I am kinda dense but why could you not charge 4 6 volt batteries in series (24 volts) then center tap at each pair of batteries to draw of 12 volts only.
Am I way off base?
You would have to be a magician to draw down each 12 volt pair equally. Discharging pairs unequally can produce a problem when recharging the batteries. One pair will reach state of full charge before the other pair. That means the charged pair gets overcharged, causes excessive water use and perhaps overheats the full batteries. Result = shorter battery life. Depending on the charger that can also mean the pair that is more discharged never gets to 100% full charge. That reduces the lifespan of those batteries.
You could run a 24 volt battery system and then use a 24 to 12 VDC converter. But that costs more and has inefficiencies. It is always better to match components properly.
MtnDon
Images: 24
Postby felixx » Wed Sep 23, 2015 3:41 pm
Also I have 1 12V battery already.
felixx
Images: 22
