Chuck Craven wrote: Oxygen mixed with hydrogen makes one big bang and all it takes is a spark.
Remember the Hindenburg it did not have oxygen to make it go bang. Just hydrogen and it melted aluminum in seconds. That whole air ship burnt up in just 10 minutes.![]()
Chuck
Chuck Craven wrote:OK
Lets see if I got it now! You are using the battery for just the inverter. Right?![]()
The Inverter does the charging of the battery!
Then all you need is a fuse at the battery just in case the wiring would short and keep the battery from blowing up. That fuse needs to be say 10 to 15 amps larger than the normal current draw so that when the inverter starts up it will not pop the main fuse from inrush current.![]()
Chuck
Sonetpro wrote:I'm using sealed AGM battery's. Fusable link doesn't burn open it just melts the wire if too much current is run through it. Chances are your car has a fusable link going from the battery to the fuse box, most manufacture's do so you wont burn up the wireing in case of a short.
Chuck Craven wrote:Well a vent at the top will let out the hydrogen gas only if you have a vent on the bottom to let in air for displacement of the lighter gas. A led acid battery 1 year old under a quick charge will produce ½ leader of out gas in one hour. Which is 70% hydrogen and 30% oxygen. It would not take long to get to 4% to go boom in a small space like a cupboard or a battery box. Oh by the way a fusible link gets hot and melts but makes a spark when it opens.
The more tired the battery gets the more it outgases. Then other gases are produced which can kill you. Even the sealed gel-cell out gasses.
If it is led acid it has to out-gas.![]()
Chuck
