Can I splice my marker lights w/my turn signals to blink?
Wiring Confirmation
Postby Engineer Guy » Tue Dec 14, 2010 10:35 am
Being on the road, I haven't looked through your Album. My oversight... There's some great wiring 'Stickies' on this Site, but the bottom line is to confirm w/the prior Owner/Manufacturer where the wiring is, and assess the accessibility of it.
4 prong flat Connectors with 4 lead flat wire is, arguably, the Industry 'standard', so you can duplicate that on any Connector added.
Trailer Wiring
More Trailer Wiring
For what your Eye can't see, one nondestructive trick is to use ye good ole straight Pin and Digital Voltmeter [DVM]. With one DVM lead jumpered to Trailer/Wiring Ground, stick the Pin through each wire of interest while checking for Tail/License Plate light; Left Turn/Stop; and Right Turn/Stop functions. As my dear ole Mom used to say, 'to assume can make an a** out of 'u' and 'me'. After confirming the wiring you have - no other wiring protocol matters - you can parallel that wiring to the rear Connector configuration you like. Most DVMs won't jump the reading clear up to +12 VDC on a turn signal voltage. They'll show ~1/2 that voltage.
The Receiver pix references were posted as idea stimulators. I thought the fellow's rear Receiver idea to provide Camper Steps and hold his Generator might be something worth copying w/modification some day. I've seen plenty of Popups carrying everything from multiple Bikes to Canoes to A/C units on Aftermarket Roof Racks, so transferring weight to the side panels - as you've shown above - works, OEM design permitting...
Engineer Guy
Images: 118
Postby Dale M. » Tue Dec 14, 2010 11:03 am
IF it were me I would splice into wiring and add a plug and supplemental lights to bike rack and go on my way.... Sort of Keep IT Simple Stupid (KISS) principle...
Also for doing trailer wiring work some times a simple test light is better than fighting with digital meter. I know digital meters are good, I have used them for years along with analog meters but some times test lamps are simplest too to work with....
Dale
Dale M.
Images: 18
Postby DIY-Stu » Tue Dec 14, 2010 8:27 pm
The vision I had was to have the bike(s) going up the galley door. But I think I just found a neat solution. ... Maybe. Something like..
http://2x2cycles.com/products/bicycle-rack/
This guy definitely thinks outside the box. but you could have your bike hanging over the galley door. instead.
DIY-Stu
Flexible Bike Rack Mount
Postby Engineer Guy » Wed Jan 05, 2011 9:35 pm
Assorted good ideas, and a good Bike Rack implementation specifically...
http://2manytoyz.com/racks.html
Engineer Guy
Images: 118
Postby Oasis Maker » Thu Jan 06, 2011 9:47 am
Thanks for pulling this little not yet done project thread back up. I received the dual marker lights right before I left for the holidays and now that I'm back will try to make time this weekend to install.
Rob if you're still checking in, I popped the case to the marker and took a look. Did you use some very small cutters to snip and separate the leads or did you just rip everything out? I think you mentioned that you might have an extra marker light laying around somewhere, if not, I'll post pics for reference (probably best to do that regardless).
Scott
Oasis Maker
Images: 187
Postby Oasis Maker » Thu Jan 06, 2011 9:51 am
Engineer Guy wrote:Assorted good ideas, and a good Bike Rack implementation specifically...
Nice link to address the larger issue at hand. Great ideas. Thanks Engineer Guy. :thumbsup:
Scott
Oasis Maker
Images: 187
Postby Oasis Maker » Thu Jan 06, 2011 9:57 am
DIY-Stu wrote:The vision I had was to have the bike(s) going up the galley door. But I think I just found a neat solution. ... Maybe. Something like..
That's putting it mildly. :o
Oasis Maker
Images: 187
Postby Oasis Maker » Thu Jan 06, 2011 10:06 am
Dale M. wrote:IF it were me I would splice into wiring and add a plug and supplemental lights to bike rack and go on my way.... Sort of Keep IT Simple Stupid (KISS) principle...
Dale
Yeah, I will probably end up doing both as both will have their purpose. Having lights actually mounted on the bike rack can serve as marker and brake lights for stopping, however, the lights would be too centered and narrow to provide any discernible direction for the turn signals.
Scott
Oasis Maker
Images: 187
Postby bobhenry » Thu Jan 06, 2011 10:29 am
Postby Yota Bill » Thu Jan 06, 2011 5:44 pm
bobhenry wrote:Here is a combo unit.
http://www.amazon.com/dp/B001V5PLBQ/ref=asc_df_B001V5PLBQ1379227?tag=thefind0267497-20&creative=395261&creativeASIN=B001V5PLBQ&linkCode=asn
note 3 wires in ~~~1ground ~ 1 turn ~ 1 sidemarker
those lights are nice because they stick out enough that they can be seen easily...but they are also bad because they stick out and often get broken...it is kind of a catch 22, but may not be such a problem with something as small as a TD, though hitting it with your bike or other objects may be a problem...just be aware that you may end up replacing them if you use them.
Yota Bill
