working on it wrote:The only item hooked up inline with the battery, not switched, is the inverter.
bdosborn wrote:working on it wrote:The only item hooked up inline with the battery, not switched, is the inverter.
Oops, there's your problem. Inverters have caps on the front end that draw a little current, even when turned off.![]()
Disconnect the inverter till you get it switched. AGMs are supposed to deal with deep discharges better; don't give up hope yet and keep charging it.
working on it wrote:(I charged it for two hours this time, cool-down for one hour following). The multi-meter showed 11.76vdc. Still not above 12vdc, but maybe following the next charge cycle?
bdosborn wrote:working on it wrote:(I charged it for two hours this time, cool-down for one hour following). The multi-meter showed 11.76vdc. Still not above 12vdc, but maybe following the next charge cycle?
I would leave it on the charger for a day or so (if it's a smart charger). The longer the battery stays at a low voltage, the more sulphation (damage) occurs.
working on it wrote: But now is not the time; do you think an overnight charge with no automatic shut-down @ 2amps would boil it? After last night's charge session, it was at 11.76vdc, and 15 hours later was at 11.53vdc. I resumed the 2amp charge.
This is the way I condition AGM batteries
3% A/H constant amperage (3 amps for a 100 amp hour battery)
Allow voltage to rise to no more than 15.2 volts. This will take time and you will see the voltage "spill" occasionally .2 or even .3 and re-climb. This is healthy.
You should monitor cell temperatures. A scanning IR reader is ideal for this. At the rate listed above cell temperatures should not rise more than 5 degrees F over ambient at 68F. But this is a total permitted rise not a sudden rise. And it applies to each individual cell.
I would love to see an amp hour meter used and limit the conditioning charge to 120% of regular amp hour capacity, regardless of the 3% - 15.2 Volt 5 degrees formula. No more than 120% regardless of other factorials. But you must start off with a battery that has been maintained at 14.4 volts for at least 48 hours.
1. Charge at 14.4 for 48 hours
2. Apply 3% amp hours constant current
3. Monitor cell temps and cease charging if cell gain is more than 5F @ 68F
4. Curtail charge at 15.2 Volts or 120% of A/H whichever comes first.
5. 7 Hours at 3 amps sounds about right for a 100 amp hour battery.
6. Make sure NONE of those cells gets too warm. This is critical.
bdosborn wrote:working on it wrote: But now is not the time; do you think an overnight charge with no automatic shut-down @ 2amps would boil it? After last night's charge session, it was at 11.76vdc, and 15 hours later was at 11.53vdc. I resumed the 2amp charge.
Here's what I found for conditioning AGM batteries on the Big RV forum.This is the way I condition AGM batteries
bdosborn wrote:I would leave it on the charger for a day or so (if it's a smart charger). The longer the battery stays at a low voltage, the more sulphation (damage) occurs.
Dale M. wrote:Let the charger sit on battery for about 12 hours at float (100% charge) to desulfate and stabilize internally (chemically)... Then see what you have ..... 15.6 volts is a bit high but not dangerous, if internal temperatures are not extreme and battery is not bulging the is not a lot to worry about....
Dale
working on it wrote:Dale M. wrote:Let the charger sit on battery for about 12 hours at float (100% charge) to desulfate and stabilize internally (chemically)... Then see what you have ..... 15.6 volts is a bit high but not dangerous, if internal temperatures are not extreme and battery is not bulging the is not a lot to worry about....
Dale
I'm going to do that tomorrow, when I can monitor it all day. I'll be in the garage transferring the battery "home" to the tongue toolbox, from the galley area, for weight balance. I'm running 4 gauge cable, replacing the shorter run of 6 gauge I'm using now. And, of course, isolating the inverter from the battery with a switch. I got lucky, and didn't lose the battery, and will take precautions to maintain it now.
