Running wires
Postby Miriam C. » Sat May 03, 2008 4:49 pm
A little search yielded the following max amp/wire gage:
10G:55A
12G:41A
14G:32A
16G:22A
18G:16A
These numbers seem to be from the site below and are for chassis wiring. The chart is great though and has a voltage drop calculator.
http://www.powerstream.com/Wire_Size.htm
Postby bdosborn » Sat May 03, 2008 5:10 pm
Miriam,
There have been links to this site before and there's a couple of problems with using the information posted there:
- They don't tell you what kind of insulation is on the wire. Different kinds of insulation have different temperature ratings.
- They don't say if the wire is in free air or in conduit. Wire in conduit holds heat in and can't carry as much current as a wire in free air.
- They don't say what the ambient temperature is. Once again, its all about how much heat the insulation is exposed to.
The chart I posted has a couple of assumptions:
- Typical PVC insulation.
- Wires in conduit (or buried in an insulated wall)
- 30C ambient temperature.
As they say on the site
"As you might guess, the rated ampacities are just a rule of thumb. In careful engineering the voltage drop, insulation temperature limit, thickness, thermal conductivity, and air convection and temperature should all be taken into account."
Here's a great wire wizard that takes all these things into consideration:
http://beta.circuitwizard.bluesea.com/
You could probably get away with using the chart with the higher wire ratings but since most people asking for information here don't have a lot of electrical experience it seems prudent to be conservative and not push the limit.
Images: 806
Postby Miriam C. » Sat May 03, 2008 6:12 pm
:thumbsup: Thanks Bruce. I had that bookmarked one time and lost the whole thing. :oops:
Bruce that chart, if you read the right column gives a lower by half amp rating than yours. I think yours is probably the more accurate. My point was that the numbers posted came from the wrong column.
The column you would need to use I think is the "maximum amps for power transmition" which seem low.
