eamarquardt wrote:I don't think that you would have to reverse the polarity when switching dc on and off on the primary side of the transformer. When you turned the dc on the primary field would expand cutting the windings of the secondary driving the current one way. When you switched the dc off, the primary field would collapse cutting the secondary winding and causing the electrons to flow in the opposite direction. Thus alternating current. There are many factors, I presume, that would be involved shaping the output wave form and I can guess what they might be but couldn't predict what the output would look like under any given circumstances.
Gus
I thought back on page 2 that all that needed to be said about GFI's had been said
Prohandyman wrote:I bypassed my breaker box and plugged the cord directly into all appliances on board and everything works! Box is wired with hot to breaker, neutral and ground to neutral buss. Should the ground be elsewhere?
Miriam C. wrote:Prohandyman wrote:I bypassed my breaker box and plugged the cord directly into all appliances on board and everything works! Box is wired with hot to breaker, neutral and ground to neutral buss. Should the ground be elsewhere?
I have my breaker box wired with a ground bar and a neutral bar (came in the box). I ran the ground to the ground bar only. The neutral goes to neutral bar only. If your breaker didn't come with a ground bar then you need one.
Inlet is wire with 3 prong so 3 screws. The ground comes through the shore power.
http://tnttt.com/viewtopic.php?t=20164
I really can't see any sense in trying to have 2 GFCI's in series anyway
