Free Wire
Free Wire
Postby Mary K » Mon Sep 04, 2006 4:01 pm
I was given some left over wire from the shop of the company I work for, it is a mix of 18/2 shielded and 16/2 shielded. From what I have read here I don't think I want to use the 18awg, but the 16/4 would be nice to run and have a second pair of wires to use for what ever future use I might want. (Of course, I'd cut & tape back the shield and what ever future use item would have to be located in the area of another fixture...Im talking 12V also)
Whada yall think?
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby Leon » Mon Sep 04, 2006 10:11 pm
Years ago we rewired a station wagon that we converted to an ambulance and used shielded wire for everything. We connected the shield on one end only (to prevent ground loops) and even with all the motor driven lights and everything else energized, we had the quietest radios of any vehicle in the area. Dodge used to use shielded wire for their Police Package back when a car didn't take 20 miles of wire.
The shielded wire will work fine, and the shielding will also give it mechanical strength. The 18 ga will work for tail lights and running lights, the 16 would be good for heavier draw.
Leon
Images: 21
Postby Mary K » Tue Sep 05, 2006 10:53 am
Leon,
Thanks, I wasn't sure if the 18 ga would be ok for trailer lights. Just assumed I'd use 16 ga, but now I know.
Thanks again,
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby asianflava » Tue Sep 05, 2006 12:57 pm
For a circuit that has a known low load, you could use the 18ga. It would be fine for the porch lights or the interior dome lights. I would recommend heavier wire for something like a 12V outlet because you don't know what you might plug in in the future.
asianflava
Postby Miriam C. » Thu Sep 07, 2006 9:16 pm
asianflava wrote:For a circuit that has a known low load, you could use the 18ga. It would be fine for the porch lights or the interior dome lights. I would recommend heavier wire for something like a 12V outlet because you don't know what you might plug in in the future.
I used 14ga because I had it. Use what ya got. 8) ;) Using 12ga for the reading lights because they are a good distance from the battery and I want the wires where no screw will go. :twisted:
Postby Mary K » Thu Sep 07, 2006 10:52 pm
Thanks All, I will be using what I got and not look a gift horse in the hinney, cause that just gross...ew!
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
