I am thinking of buying a 230 amp welder but only have 120 AC household current. I want to make a pigtail like the following pigtail as described on intenet:
"Posted by Van_Camper Ontario (My Page) on Thu, Nov 3, 05 at 21:21
I bought a Cannox 230 amp AC stick welder about 30 yrs ago, and never had a problem with it. I also started using it on 120AC household current. All I did was add a 2 foot pigtail with one end having the 230amp plug and the other the 120 plug. I also bought 70 feet of 9 gauge wire to extend my working distance (I know, not first choice, but it works fine)and plug this into 120. I have turned the welder up to 155amps and welded 1/4"). Point is, it works on both current types, is portable, and will cover anything you need to do around the home. Migs/Tigs are all great, but cost more and uncessary for the average guy wanting to do some repairs around the house, or build a trailer. "
So how do I make one? I did a web search and only came up with a 220 volt converter to 120 volt pigtail like the following: I don't think this will work for the purposes he described.
http://www.toolprice.com/product/9060C
Thanks so much!
