http://www.timage.eu/Productimage.aspx?id=938
I want to use a small 7Ah lead acid battery. But at 10 to 20 watts I would only get 9 to 10 hrs use. There are LED based bulbs which are very energy efficient.
http://www.ultraleds.co.uk/default.php?cPath=74
http://www.ultraleds.co.uk/default.php?cPath=51
But I could not find a G4 size for "end on" use which would fit so I made one and here it is.
It work very well gives as much light as a 10 watt bulb for just 1 watt. The life expectancy is 100,000hrs and will be damaged less by vibration and rough use.
*** my IE7 shows no picture here !!! ****
*** but my Opera does *****
*** however the pic is in my album****
