doug hodder wrote:What about putting an exterior GFI receptical in there...you get 2 110 outlets and it's protected, put a plug on the lead for the rest of the trailer and plug it in, still gives you 1 more outlet to use...just a thought...but I'm just a 12 Volt builder...Doug
doug hodder wrote:John...you might want to total up the amperage that you may be using at any 1 time...how many appliances do you plan on running...got AC? you are showing a 15 amp breaker in the box up front...will that give you enough? If you have that or a GFI do you think you'd need another in the galley?....and none of it is to code, but I'd think protection right up front will cover the rest of the tear...but again...I'm not an electrician...Doug
