Can I use this Fuse holder
Postby Mary K » Mon Feb 26, 2007 3:10 pm
http://www.tessco.com/products/displayP ... ventPage=2
I would like to use this fuse holder in my TD. I like the blade style fuse. Does anyone see any problems with using it?
Thanks,
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby Steve Frederick » Mon Feb 26, 2007 3:20 pm
Hey MK! I used this style fuse holder on all of my projects.
Try Waytek
I like the way that the battery cabling hooks up to the line side.
You also have a terminal strip for the ground side of each circuit.
You're on the right track! Lookin' good kid!
Last edited by Steve Frederick on Mon Feb 26, 2007 3:27 pm, edited 1 time in total.
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby Mary K » Mon Feb 26, 2007 3:27 pm
Steve Frederick wrote:Hey MK! I used this style fuse holder on all of my projects.
Try [url=http://order.waytekwire.com/CGI-BIN/LANSAWEB?WEBEVENT+L0C06080D39748700680D051+M37+ENG[/url]
Thanks Steve.
BTW, Your linky is not working :oops:
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby Steve Frederick » Mon Feb 26, 2007 3:28 pm
Thanks Steve.
Mk
Just fixed it!! I'm "working" ha-ha!
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Postby Dale M. » Mon Feb 26, 2007 4:10 pm
The " ATO/ATC " fuse holder that Steve recommended is probably easiest to wire to, plus has "ground" connections also. And it can be wired after you mount it.
Other style requires all wiring from bottom so it all has to be in place before you can mount fuse holder, and has no provisions for grounds.
Dale
Dale M.
Images: 18
Postby Mary K » Mon Feb 26, 2007 4:58 pm
Dale M. wrote:The " ATO/ATC " fuse holder that Steve recommended is probably easiest to wire to, plus has "ground" connections also. And it can be wired after you mount it.
Dale
Dale, Thanks :thumbsup:
I don't mind installing after I wire. And I already have a ground bar to install. I plan on mounting all electrical components on a panel then installing it in the raceway. (Generic Benroy build).
I just wanted to make sure that I could use the blade style fuses.
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
