120VAC Power Inlet
120VAC Power Inlet
Postby Mary K » Thu Mar 29, 2007 11:40 am
I had a few folks ask me where I got the Power Inlet for my TD, so I thought I should post it in case others would like to know. I found this part/info somewhere here on the forum long time ago.
I bought this inlet from the Bass Pro Shop online. Bass Pro Shop
It's $14 and a good deal. I used a 2" hole saw (they say use 1 7/8") and used the screws provided to install. My 3/4" side wall was to thick to use the nut thingie ??? on the back side. (I don't know what it is called) I put a bead of silicone around it just for added protection from leaks.
I wired it straight to a GFCI receptacle and daisy chained the other receptacles to it.
Mary K.
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby NutmegJoe » Thu Mar 29, 2007 12:31 pm
Thanks Mary! I'm using the same inlet for shore power and was planning on installing just like you! Wasn't sure if that was the way to go...now I know I'm on the right track!
Shelly
"Do what you like,
Like what you do"
NutmegJoe
Images: 54
Re: 120VAC Power Inlet
Postby Steve Frederick » Thu Mar 29, 2007 1:44 pm
Mary K wrote:I had a few folks ask me where I got the Power Inlet for my TD, so I thought I should post it in case others would like to know. I found this part/info somewhere here on the forum long time ago.
Mary K.
Exactly the one I use, and exactly the method!!
Great minds think alike??? :?
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby Mary K » Thu Mar 29, 2007 3:03 pm
Steve Frederick wrote:Exactly the one I use, and exactly the method!!
Yes, they do. :wacky :lol: ;) :D
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby Mary K » Thu Mar 29, 2007 3:11 pm
Just thought I would post some more pic's on the inlet install.
A picture is worth a thousand posts... so do I qualify for the 3000 posts club??? :lol: :lol:
Oh, I ended up taking out the Romex stiff A$$ wiring and replaced with stranded 12awg wire.
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby DaveandDebbie » Sat Apr 14, 2007 11:06 am
Looks great MK
Correct me if I am wrong But how are you going to keep the smoke in the wires would you not still need some sort of over load protection IE circuit breaker or fuse :thinking:
Dave
DaveandDebbie
Postby DaveandDebbie » Sat Apr 14, 2007 11:52 am
Mary K
I just read your other tread I see you are using a 40' 15amp lighted Circuit Breaker extension cord. That should keep the smoke in the wires :thumbsup: Dave
DaveandDebbie
