You could also wire it in from brake light switch (under dash?) all the way back to tow connector if you have a unused pin in connector...
Trackstriper wrote:Dale-
I think that the diode diagram in your earlier post will flash the third brake light when the turn signals are used while the brakes are not applied. It may take that extra wire from the brake switch, or from a tap at the brake light if there are seperate brake and turn indicator bulbs in the tow vehicle. Let me know if I'm wrong here, it's kinda late now.
Bruce Robertson
