battery gurgling
battery gurgling
Postby Aaron Coffee » Wed Jun 06, 2007 4:21 pm
Hooked up my new promariner6 charger and the battery was making a gurgling sound. Just wondered if that is normal or not. I had it hooked up before and fully charged the battery. Then unhooked it to mount it in the battery box.
Thanks
Aaron Coffee
Images: 26
Postby sdtripper2 » Wed Jun 06, 2007 4:59 pm
Arron:
Promariner6 charger that you mention is that the ProSport 6 Charger?
What type of battery do you have and how old is it?
Lead Acid?
Gel Battery?
Does the battery hold a charge?
This gurgling sound could very well mean your over charging your battery~
Here is a couple of reads about battery gurgling sounds while charging :
http://tinyurl.com/369p7x
http://tinyurl.com/36w3dp
sdtripper2
Search Garoux
Images: 168
Postby Chuck Craven » Wed Jun 06, 2007 5:04 pm
ARRON
If you are charging a wet cell battery and then move it. The battery will make a gurgling sound because some of the outgas will get trapped between the plats inside. If it is gurgling with the fill caps on when charging then you have a problem!
Chuck
Chuck a new td builder
Chuck Craven
Images: 62
Postby tonyj » Wed Jun 06, 2007 5:21 pm
If it is a wet cell battery, check your water level. It will also make the sound if the cells are low on water and the charger is charging at full power.
tony
tonyj
Images: 160
battery gurgling
Postby Aaron Coffee » Fri Jun 08, 2007 4:31 pm
you're right it is the prosport. It's a wet cell a year or two old. I had just moved it and it is a little low on water. I use distilled water right?
Aaron Coffee
Images: 26
Re: battery gurgling
Postby tonyj » Fri Jun 08, 2007 4:34 pm
Aaron Coffee wrote:you're right it is the prosport. It's a wet cell a year or two old. I had just moved it and it is a little low on water. I use distilled water right?
Distilled water is recommended.
tony
tonyj
Images: 160
