Hi, I'm wiring up the 4-prong plug on my Volvo, and also doing the tail/turn/brake lights on my work in progress TD. I have a harness on the vehicle, with a converter, that I bought at NAPA. On the trailer are generic flush mounted taillights installed on the galley hatch, with a ground wire running from each light housing to a splice, and then to the trailer frame screwed onto bare metal. The taillights work fine, as does the right turn signal, but when I turn on the left turn signal both tail lights blink. Upstream from the converter (in the car) the connectors are working fine, but somewhere after the converter it seems as though when I run the left signal it sends juice to both sides. Does this sound like a bad converter? I hear that they are cranky sometimes. I'm not an electrical guy by any stretch, this is all at the limit of my understanding, so my apologies if I am being less than clear.
Thanks in advance,
Andy
