This may be a good thread. Or there may already be one that I haven't found yet that is suited for this...
Anyway, Battery Isolator on closeout at HF for $20
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=93801
Cliff
Battery combiner relays are the new way to go. They isolate the two batteries all the time until they sense a charging voltage above 13 volts and then they combine the two batteries with a high power relay, so both get a full charge. When the charging voltage goes away, the relay opens and the batteries are isolated again
