Inteli-Power Electronic Power Converter
Postby benzu » Sat May 10, 2008 8:55 pm
I have this converter but have no idea how to connect the positive and negative wires to it. Are there special connectors for this converter? Where do I get them?
Thanks,
Mike
benzu
Images: 119
Postby Joe G » Sat May 10, 2008 9:57 pm
Mike,
I looked through the installation manual and they didn't mention anything about a special connector plug. Looks like you place a 2 to 14 gauge wire in the output terminal and tighten it down with an 5/32" Allen wrench. All I have to go by is a drawing. Could you post a picture of the output terminals?
Joe
Joe G
Images: 25
Postby benzu » Sat May 10, 2008 10:16 pm
Joe, thats the first i've heard of using an allen wrench. I'll try that tomorrow when I have more energy.
I don't have a picture of mine but here's a better picture which I'm sure you have already seen.
Thanks,
MIke
benzu
Images: 119
Postby jss06 » Mon May 12, 2008 7:53 pm
I have the same converter. The allen screw tighens down on bare wire to hold it in place. No special connector required.
jss06
Palladium Donating Member
Postby benzu » Mon May 12, 2008 11:33 pm
Thanks for the info, I tried that yesterday. Got everything wire only have to ground the converter and the battery and I'm set. Then finish up the running lights and close her up. I hope I can get this thing done in the next four weeks.
Mike
benzu
Images: 119
