When the solar panel is in the shade, it shuts off completely. -Mike
TPMcGinty wrote:I was looking on Northern Tools web site at a 5 watt solar battery charger. The people who reviewed it said it worked even on a cloudy day. I don't know if it would work in the shade, but at least in the shade there is some light. It's on sale for $50, so I think I might give it a try.
madjack wrote:Tim, keep in mind that a 5w chargers is more of a maintainer than a charger...if you are wanting to extend your stay, you need a bigger charger like Ed's 33w unit...Harbor Freight sells a 45w unit, complete with a solar charge controller for around 220 bucks..... http://www.harborfreight.com/cpi/ctaf/d ... mber=90599
madjack wrote:...for example, a 45W panel with 8hrs of solid sun would yield you around 24-30Ah of power feed into your batteries...quite a bit for our basically minimalist needs......
madjack wrote:Tim, I agree it is lot to carry/setup but for the price it may be worth it...I have seen single panel setups that went as high a 75W and higher...with a commensurate increase in price...my main point was the fact that the smaller 5-15W panels may not do what you want...I don't have any solar experience but my research has indicated to me that a 30-45W panel is about the minimum I would want to extend my stay in the boonies...for example, a 45W panel with 8hrs of solid sun would yield you around 24-30Ah of power feed into your batteries...quite a bit for our basically minimalist needs......
Joseph wrote:Solar panels are like swamp coolers - they work best in the desert southwest.
brian_bp wrote:madjack wrote:...for example, a 45W panel with 8hrs of solid sun would yield you around 24-30Ah of power feed into your batteries...quite a bit for our basically minimalist needs......
I think that's solid sun... at the equator, in midsummer, at noon, with no clouds, no dust on the panel, and perfect panel alignment. From what I've read, I'd divide by two for more realistic conditions, even without considering shade. But then, maybe I'm just a pessimist.
