halfdome, Danny wrote:Mine is a five wide but you could do the same in a smaller TD.
I got mine from (bolt in boxes) speedway motors
(weld in boxes) speedway motors:D Danny
tinksdad wrote:halfdome, Danny wrote:Mine is a five wide but you could do the same in a smaller TD.
WOOHOO!!!! As soon as I saw this I had to run outside and crawl under my TD to see if I could retrofit one of these to my frame. I think it's do-able. Anything to save precious space!!
Russ in California wrote:Danny, do you foresee any problems with the batteries being 'down under' with road debris and all? Mostly on the pavement are you?
Since I'm going 'bush' with mine, well that's the intension, I didn't think I'd want mine under even though that's a great spot to save room.
I'll have to think about that. I'm not going to bash rocks so that spot might be a consideration.
Are those 12v batteries?
thanks,
Steve F wrote:My battery is a fully sealed 100AH AGM and lives on a slide behind the switch panel under the bench. It's space that was going to be wasted with the switch panel anyway and is easy to get to when the battery needs a top up. I also have a plug on the front of the switch panel (not in this pic) that is for the solar panel, the regulator is also mounted in here with the battery. I like Dannys idea but with my offroad trailer I'd worry about mud and rocks damaging my expensive battery and leaving me powerless
Cheers
