by madjack » Sat Apr 25, 2009 10:26 pm
...sounds like you need an AC distribution system...an inexpensive, small(4 to 8 ) breaker box can be had from any of the box stores...wire this for a 12 ga. extension cord to the shore power so it becomes your main inlet for 120vac...add breakers as needed and run your AC circuits to the appropriate breakers in the box...another option is to buy one or two 6 outlet strips with breakers/GFIC built into them...wire them to take input from that same 12ga extension cord to shore power...run your assorted 120vac circuits to the strips and just plug 'em in...one of the most important things is to remember to have a GFIC setup somewhere in the upstream section of the system......
