electrical
electrical
Postby john curtis » Mon May 11, 2009 11:24 pm
I am so confused :thinking: I bought a paralax 6730 power center,now do I have to use a 30 amp outlet for the shore power or can I use a 20 amp outlet :shock:
john curtis
Images: 141
Postby wlooper89 » Tue May 12, 2009 9:55 pm
John,
It really depends on your power needs. In general a converter just passes AC power through to the trailer in addition to powering itself. I am not sure what size your converter is but for comparison a 25 amp DC converter will use about 4 amps AC. I decided to install a 30A power inlet and use a 30A cable from campground power. Then I suggest split into two 20A AC circuits with a 20A CB and 20A GFCI on each. This way you can use up to 20A on one circuit but the total should stay below the campground CB limit of 30A. My reason for this suggestion is that 20A components from Home Depot or Lowe's are much less expensive than 30A ones ordered online.
I was thinking microwave oven, electric blanket and coffee maker, AC things like that. If you do not mind a simple electrical formula, it is Amps = Watts/Volts. (Watts divided by Volts) This will give the amp draw of an AC appliance if the number of watts is known.
Bill
PS A converter does not exactly fit the above formula because of inefficiencies in the circuits and heat generated.
wlooper89
Images: 75
power outlet
Postby john curtis » Wed May 13, 2009 9:29 pm
Thanks for the reply.I have a 30 amp converter.So from what I understand I think I should be able to use a 20 amp connector on the trailer,I hope.
john curtis
Images: 141
Postby Uncle Chan » Wed May 13, 2009 10:02 pm
John, I'm in the process of doing the same thing with the same Parallax converter. I'll bring a 30amp line into the camper and split it off into 1 20amp and 2 15amp circuits.
But to answer your question, yes you can use a 20amp line. But why would you? Put in a 30amp inlet and get a little line converter to run it off a park's 20amp service, if that is all they have.
U.C.
Uncle Chan
Uncle Chan
Parallax Instal Instructions
Postby john curtis » Thu May 14, 2009 9:44 pm
Had to e-mail Parallax for instal instructions for their 6730 power converter.If anybody can use these help your self.I hope this link works,not to sure on how to post this.
http://ca.mc566.mail.yahoo.com/mc/showM ... j3on9yMoqG
john curtis
Images: 141
Re: Parallax Instal Instructions
Postby Miriam C. » Thu May 14, 2009 10:17 pm
john curtis wrote:Had to e-mail Parallax for instal instructions for their 6730 power converter.If anybody can use these help your self.I hope this link works,not to sure on how to post this.
The link goes to Yahoo mail sign in. To put the info on here you need to go to the site with the info and copy the http address, just click on it with your right button and copy. Then come here and paste. You can edit your post to do that or make a new one. :thumbsup:
Bad link
Postby john curtis » Thu May 14, 2009 10:30 pm
This was an e-mail to me in a adobe.Dont know how to post it with out it going to my e-mail,or how to edit or delete it.
john curtis
Images: 141
Re: Bad link
Postby Miriam C. » Thu May 14, 2009 10:36 pm
john curtis wrote:This was an e-mail to me in a adobe.Dont know how to post it with out it going to my e-mail,or how to edit or delete it.
Simpler yet! If it isn't too long you can highlight the material, copy and past here.........Or you can forward it to one of us and we can try to find it on the internet........ 8) Might take me till tomorrow........ :thumbsup:
Oh yeah put TTT in the topic line so I won't think it is junk mail. 8) :lol:
PS you can copy the link in the email. Just right click on it and copy. Paste it here........ :twisted: Just go to your email.
Instructions
Postby john curtis » Thu May 14, 2009 10:38 pm
john curtis
Images: 141
Postby Joe G » Thu May 14, 2009 10:39 pm
Hey, I found some manuals on the Parallax site:
Install Manual
Product Brochure
(from install manual)
Input Supply Requirements
This unit is suitable for direct connection to a 30 Ampere, 125 Volt Recreational Vehicle power supply assembly
(from product brochure)
....Included are one 30-amp main AC circuit breaker....
This unit is designed to be connected to a 30 amp service. Unless you use a lot of 120 AC power, you shouldn't have any problem powering it with a 20 amp service. It will still put out the full 30 amps DC for your 12v circuits.
Hope this helps.
Joe G.
Joe G
Images: 25
Electrcal
Postby john curtis » Thu May 14, 2009 10:40 pm
Thanks for the help,figured out that part,now how do I delte the bad link
john curtis
Images: 141
Re: Instructions
Postby Miriam C. » Thu May 14, 2009 10:43 pm
john curtis wrote:http://www.parallaxpower.com/6700/6730_Installation_Guidelines.pdf
There ya go! :thumbsup:
Re: power outlet
Postby wlooper89 » Mon Jun 29, 2009 7:19 pm
john curtis wrote:Thanks for the reply.I have a 30 amp converter.So from what I understand I think I should be able to use a 20 amp connector on the trailer,I hope.
That is what I am thinking too because of the amp difference between 120V and 12V. The 30 amp converter may only draw about 4 or 5 amps AC including heat generated,
etc. So you would still have 15 amps from the connector for other AC loads. I went with a 30 amp connector and power cord, but 20 amp may be fine for your setup.
Bill
wlooper89
Images: 75
