Line Filter
Line Filter
Postby Forrest747 » Sun May 31, 2009 12:13 am
I have come across a line flilter that helps smooth out electircal spikes. I am thinking of adding this to my system. nayone else use these. I am thinking just one more thing to aid in keeping the electrical system safe. or just another thing to get fried.
Forrest747
Cowbell Donating Member
Images: 447
Postby Boodro » Sun May 31, 2009 8:17 pm
Hi , just a question. Are you running any sensitive electronics?( laptop,dvd,expensive stereo) If you are you may need it for peace of mind. If you are just running lights,coffee maker,microwave etc. most campground power would be good as long as you have the needed power breakers or fuses in place in your system.
Just my 2 sense!! Good luck! :applause: :applause:
We are all travelers in this world , from the sweet grass to the packin house , birth till death , we travel between the eternities . ( Robert Duvall as Prentiss Ritter)
Boodro
Images: 101
Postby Lgboro » Sun May 31, 2009 10:26 pm
If you are running led lights you will need to regulate the current or your leds will burn out prematurely. (or use resistors to reduce the current each led receives)
Lgboro
Images: 53
Postby wlooper89 » Sat Jul 04, 2009 11:28 pm
I have always thought of campground power as pretty much the same as residential power. So I would not expect any special filter to be necessary. Maybe a surge protection device for electronics.
If converting 120 AC to 12 V DC then some filtering is necessary. I prefer to call it smoothing. But terminology aside, a transformer can convert 120 AC to 12 AC and then a bridge rectifier can change the current to 12 V pulsating DC. A capacitor then smoothes out the pulses to provide normal 12 V DC. This is what a converter basically does.
This all came to me while staying at a Holiday Inn Express. :D
Bill
wlooper89
Images: 75
