Which did you use, and why.
I see a lot of both, but can't seem to find what the benifits of one over the other are.
dh wrote:Which did you use, and why.
dh asks...
Battery tender or 12V converter/charger...
http://batterytender.com/resources/selection-guide.htm
What type of battery will be recharged?
Flooded, Sealed, VRLA, AGM, GEL, etc.
How large is the battery?
This is the capacity in amp hours. Some batteries will not have this number displayed on their label. Typical labels will show either CCA (Cold Cranking Amps) or Reserve Capacity in Minutes. Reserve capacity is the number of minutes that the battery can deliver a constant 25 amps to a load.
How is the battery being used?
What is the application? SLI, Deep Cycle, or Standby Power.
How deeply will the battery be discharged?
Shallow cycling (discharging 20% to 50% of the battery’s capacity) does not usually require as much recharge power as deep cycling (discharging more than 50% of the battery’s capacity).
How often will the battery be discharged?
In general, the more often the battery is discharged, the higher the power you want to use to recharge it. This is particularly important if the battery is deeply discharged. A good rule of thumb for deep cycle batteries is to only discharge them once every 24 hours, otherwise there may not be sufficient time for the batteries to recover between discharges. This has been a serious point of concern for many industrial applications. It has also been a great disappointment to many consumers who have expected to be able to repeatedly discharge large deep cycle batteries and then recharge them with low power chargers.
How much time is available to recharge the battery before it has to be discharged again?
This question is where many industrial systems designers get into trouble. Industrial battery use is usually the most demanding, particularly with electric vehicles that require a mixture of high and moderate rate deep discharges. Time must be allotted not only to recharge the battery, but also to let it rest in a fully charged state between deep, high rate discharges. If you need to replace 100 amp hours in 4 hours, then you need at least 25 amps. However, the truth is that you will need 30 to 40 amps or more and probably 6 to 8 hours because of the way that chargers and batteries behave after the battery is 80% recharged. It is more difficult, and it takes a lot longer to replenish the last 20% of the battery charge than it does to replenish the first 80% of the battery charge. Even if you can get the battery completely recharged in 6 to 8 hours from a deep discharge, it is still not wise to deeply discharge a lead acid battery more than once a day.
