I was going to suggest that too, until I saw the $3.99 price tag on the HF switch.Corwin C wrote:If you really want to do this (sounds like an expensive, challenging endeavor for coffee, but there again I'm not a drinker...) I think that you're going to need a 200 amp relay rated for continuous duty. That way the remote switch wouldn't have to handle all of that current.
Kevin A wrote:I was going to suggest that too, until I saw the $3.99 price tag on the HF switch.Corwin C wrote:If you really want to do this (sounds like an expensive, challenging endeavor for coffee, but there again I'm not a drinker...) I think that you're going to need a 200 amp relay rated for continuous duty. That way the remote switch wouldn't have to handle all of that current.
timlsalem wrote:well, let me go check out what a 200 amp relay is but my coffee pot is 900 amp and the switch says it can handle 1000 so don;t really know if the relay is needed.
You might want to check that again, I'm thinking you mixed up amps and watts.timlsalem wrote:well, let me go check out what a 200 amp relay is but my coffee pot is 900 amp and the switch says it can handle 1000 so don;t really know if the relay is needed.
