Deep Cycle Battery usage
Postby cannon253 » Mon May 10, 2010 3:23 pm
Can any one out there tell me where to find a usage chart so I can estimate how long my battery will last?
Thanks
cannon253
Postby Miriam C. » Fri May 28, 2010 1:09 pm
This might help you. The battery tells you the info you need really. http://www.calculatoredge.com/electronics/battery.htm
Not so sure.
Postby eamarquardt » Fri May 28, 2010 6:11 pm
Miriam C. wrote:This might help you. The battery tells you the info you need really. http://www.calculatoredge.com/electronics/battery.htm
The general rule of thumb is that you shouldn't draw more than 50% of your batteries rated capacity before recharging it. I visited the site above and it calculated the life of a battery by discharging 70% of it's capacity. This would result in degraded battery life.
You can figure out your draw (amps X hours) for what you want to run, add them up, and compare to 50% of your batteries rated capacity.
Hope this helps.
Gus
eamarquardt
Images: 150
Re: Not so sure.
Postby PaulC » Fri May 28, 2010 10:45 pm
Hope this helps.
Gus
Hey Gus, that's the general rule for normal batteries, deep discharge can handle up to 80% discharge and still give good life. AGM, Gel etc type discharge are actually designed to handle greater loss than your normal lead acid.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Re: Not so sure.
Postby eamarquardt » Fri May 28, 2010 11:17 pm
Hope this helps.
Gus
Cheers
Paul :thumbsup:
Nice bicker! :applause: You're right that deep cycle batteries can handle 80% discharge w/o damage. Check out this web site,
http://www.windsun.com/Batteries/Battery_FAQ.htm
If we don't bicker, no one learns anything. :applause: So now we need to know what type of battery cannon253 is using as the discharge level can range from 50 to 80 percent. Once we know, we can give better advice. It would also help to know the discharge rate as it, too, is a factor in the "equation". :thinking:
Gus
eamarquardt
Images: 150
