Could use some advice
Postby bradp » Mon Jul 26, 2010 9:07 pm
So here's the deal. I'm going to order a Silver Shadow 5x10 in September and I need some advice on the electrical. The shadow comes with a Dry battery that is a 29 amp/hr. Our electrical needs will be running the fantastic fan, some LED lights, using our laptop to check email and weather conditions and maybe a radio. We also want to install a solar panel that can handle the recharging.
All this with the thought that we won't be hooked up to shore power. What can anyone recommend for a battery upgrade and a solar panel to match the battery upgrade. I'm just a very non electrical person. I think that if I get the battery and panel I can have Little guy mount them for me when they build the trailer.
Thanks for listening
bradp
Postby S. Heisley » Mon Jul 26, 2010 10:06 pm
I can't help you with the solar end of things; but, I might be able to help you figure out what size battery would work best for you and that is a good starting place.
You need to list every DC thing that you will be using your battery for. Write down what it is and how long you think you will use it each day. Look at each of these DC lights/fans/DVDs etc. and write down the Amperage (Amps) that each says it uses per hour. From that, you'll be able to calculate how many Amps you can expect to be using per day. Multiply that times 3 and then multiply that times the number of days you will usually be "off grid" and between chargings. That will tell you what size battery you will need. Once you get your solar charger set up, the number of days between recharges may need to be modified; but, keep in mind that, depending on the amount of available sun, your solar unit and its size and your Amp usage, you might be only supplementing and not fully recharging.
The reason for multiplying your expected Amp usage by 3 is that anytime you use more than 50% of your battery's Amp capacity, you shorten the battery's life. The current belief is that using no more than one third of the battery capacity will help give you maximum life from it.
Although a bit more complex that you need, you may be able to glean what you need from my calculation sheet and make a simpler one:
As far as what battery to use, I went with an MK AGM battery.
...Maybe someone else can chime in with information related to solar and some other information.
Postby starleen2 » Mon Jul 26, 2010 11:01 pm
I say bookmark this chart folks - you'll be lookin' for it later - thanks S. Heisley
starleen2
5th Teardrop Club
Postby bradp » Tue Jul 27, 2010 8:18 am
Thank you Sharon!!
bradp
