dreadcptflint wrote:Remember to keep it simple. Just stick with a 12 volt system, there are plenty of appliances out there for a 12 volt system. Focus on the connection between the trailer and the car to charge your battery.
What dreadcptflint said plus:
If you need to charge an electric razor or your laptop charges off house current then you can install a little 200 watt inverter. It converts 12 volts to 110 so you can plug in things from home. A small one like this doesn't drain the batter too much and makes it convenient so you don't have to purchase a lot of 12 volt chargers. They sell inverters online, at automotive stores, even walmart.
Also, If you happen to park at a campsite that has a 110 volt connection a simple solution to not having a whole other set of wiring in your camper is to buy a small battery charger. Marine ones are nice. Plug the charger in to keep the battery charged and run everything off 12 volts.
Conform and be dull.
