Two LED interior lights, one, 50 bulbs. Any one using these
Postby kayakrguy » Sat Aug 14, 2010 8:23 pm
Hi everyone,
I have found a 50 bulb LED surface mounted interior light at: http://tweetys.com/14-50-led-surface-mo ... light.aspx
They also have this double dome light:http://tweetys.com/double-dome-white-led-surface-mount-interior-light-kit.aspx
Does anyone have any experience with either of these products? If so, how well do they work for you?
I am thinking of getting rid of my incandescent dome lamps in the cabin and galley and going all LED--reading lamps already are LED. I wanna be able to use battery power longer between using shore power...
Best to all,
Jim
A disposition to preserve, and an ability to improve, taken together, would be my standard of a statesman...
But what is liberty without wisdom, and without virtue? It is the greatest of all possible evils; for it is folly, vice, and madness, without tuition or restraint.
Edmund Burke
kayakrguy
Images: 195
Postby bc toys » Sun Aug 15, 2010 9:50 am
it is not 50watt it is 4.2 watt it has 50 led lamps it still would work well in a td
bc toys
Images: 42
Postby Shadow Catcher » Sun Aug 15, 2010 3:09 pm
From experience, if any thing it likely to be a bit too bright. None of ours have more than 12 SMD's
But it will work.
Postby Cliffmeister2000 » Tue Aug 17, 2010 8:37 pm
Thanks for posting that link. They had a license plate frame with LED light that I've been looking for! :thumbsup:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby S. Heisley » Wed Aug 18, 2010 8:35 am
Interesting. When you get it installed, could you please post a picture of it, turned off and on?
I installed a florescent fixture that is about that size but I'm not totally happy with it (too bright). Yours uses .35 amps to my florescent's 1.4 Amps and it would be slightly safer, so that's a bonus, too.
Postby kayakrguy » Sat Aug 21, 2010 10:41 pm
Hi folks,
We're on the road from NY to Seattle and Portland via Colorado and RMNP--so I have not been on-line. I am still debating getting the LED's. The 50 bulb one I would probably put in the galley to replace the two incandescent 12v dome lights we have there. We have two LED reading lights which are fine for defined beam reading use. They would not be so hot for area lighting use....
Jim
Edmund Burke
kayakrguy
Images: 195
Postby zipz71 » Sun Aug 29, 2010 3:08 pm
I used this one to replace the lamp in my dome light
http://www.superbrightleds.com/cgi-bin/ ... mp_T10.htm
I used the 24 led one. It's good enough that I'm going to leave it but a warmer colour and maybe a little brighter would be nice.
I used this one in my galley ( 12" - 30 led warm white).
http://www.superbrightleds.com/cgi-bin/ ... W30SMD.htm
I'm very happy with the brightness, colour and coverage.
Jeff
zipz71
